Thermal barrier/heat shield?
Mike R
Contributor
Anybody know of a inexpensive thin heat insulation? I'm going to make a ram air using the stock air box and piping, and I want to insulate the bottom of it from the radiator heat.
sheet aluminum alone will heat soak rapidly; perhaps make a composite of the insulation between Al sheets....
The aluminum would work, but would require alot of forming to look decent and fit under the stock stuff. The mat looks like it'd work, but I dunno....maybe an aluminum cap on the rad instead of the bottom of the intake. Wonder if there is a spray insulator, that'd be the easiest for me. Kinda like jet hot, but that'd work on plastic.
I used aluminium drier duct. It seems to work better then I thought it would. Also you can buy all that stuff their listing at www.jegs.com They have tons of stuff in that nature. Usually stuff like that you can find at the good old boys shops.
