the forums on firefox...
fLyPiNoY7
Return of the Evil Monkey
2003 Sunlight Silver Protege5
i dunno if im the only one having this problem, but the forum crashes whenever i try to access it using firefox...right now im using ie and it works fine, but whenever i try to use firefox, nothing...any ideas?
hmm...yeah, thats probably y it isnt working...funny though, i never got the little "update now" button...
hmm...just updated...still same issue...it would load up the main page of the forum then just stop working...never did that with any other websites...and they still work...
I have 1.0.7 too and the forum seems to work for me, all though it does have the tendency to occasionally stall out after browsing for extended periods.
SenorCorwin said:
its a firefox thing... simple answer... use IE
A true IT Pro :P (rofl)
yea, ive been to lazy to fix stuff before and I would give an answer like that.
- deinstall ff completely,clean the registry, reinstall ff
- get firetune or fasterfox (plugin)
Do you have any extensions installed? If so, try disabling them and see if that helps anything. Been using firefox on the forums since I joined, and never had the problem you are describing.
just noticed something new...if i try to get on the forums using firefox, it stalls...then i would try to log on using ie and it wont work either...if i close all windows for a bit and reopen ie, it will go to the forums just fine...connection issue?...and tstar, tried and installed everything that u said...problem still exists...
