Tein S-tech Installed
Mazda 6i Charcoal Grey
Here are some pics. sorry its dirty, finally stopped raining. 2"drop in front 1.5" in back.
Sweet! How's the ride compared to stock? Do you get that certain "float" like on the stock suspension? Very curious because I like the drop and small rake.
camber isnt bad at all . the ride is a bit diff from stock. personally i think i should have cut more from the bump stops. some pot holes feel really hard. but other than that its nice. i love the drop these spring did for me.
is it stiffer than stock? that my main concern cause the listed spring rates are softer
The rates I found for them are 163 lbs/in Front and 241 lbs/in Rear while the stockers are 188 lbs/in Front and 171 lbs/in Rear. So you know the rears are stiffer for sure and the the fronts are a little softer.
