Suspension noise, swaybar links?
I recommend locktite and make sure to hold the jam nut on the inbound side of the link, seems to be overlooked regularly.
I've been hearing a clunk sound coming from the right side front whenever I go over a bump that causes the suspension to droop at all ever since the car was new, and recently it's been getting more frequent and a bit louder. I even hear it when going around high speed right turns now. I can't see anything obvious wrong with the links or suspension in general -- would swapping out to the Raybestos links be the solution? I don't really want to bring it to the dealer, but I guess that could be an option..
First thing I would do is check and make sure the endlinks are on good and tight (they can look OK and still be loose, it doesn't take much to make alot of noise). And if you have an aftermarket swaybar, make sure it hasn't walked over to the subframe.
