Tried posting this in the suspension section but didn't get a response.
I am getting close to dropping the p5 and just have some quick question for you suspension gurus. Hopefully by the end of this i won't come off as too much of a noob and get my moderator status taken away
First off I want to make sure I have everything set to go when I install the springs, struts and rear sway bar.
Things i have/am buying soon:
-Eibach Pro-Kit
-Tokico Blues
-Progress rear sway bar
-Front and rear AWR endlinks
Here is where I need some advice. What else will I need? I believe i need to cut the bump stops like two notches? What else do I need to take off the stock suspension? Anything else I should look out for in the install.
My next set of questions involves camber. I want to run some negative camber. Now to do this, do I need to buy camber bolts or some other camber items or would the alignment shop be able to set the camber I want? How much camber would be good to run front and back?
Thanks for any help you guys/gals can give! I will be posting pics when it is all said and done.
-Eibach Pro-Kit
-Tokico Blues
