Suspension/Brake Torque Specs
I've searched with no success. I'm looking for torque specs for the following :
Front Caliper Bracket Bolt torque spec :
Front Sway Bar End Link torque spec :
Front Outer Tie Rod torque spec :
If you could help, thanks.
Cool. I found what looks like the Caliper Mounting Bracket Bolt Torque spec under Brakes04 > Convention Brake Systems > 04-11-17. To me it looks like its saying to torque the bolt to between 58-75FtLbs, if you could confirm thats correct, thanks.
