well the question you should ask yourself is does SURE (Street Unit) give you a life time warranty for the mount? like CP-E...
Even tho EVERYTHING they offer is copied from CP-E and COBB....Soes that answer your question?
I hardly think that everything is copied. The pieces may look similar, but the R & D behind the design are completely different. The intakes look similar, but maf housing specs are optimized in the SURE products. The same goes for the inlet, engine mounts etc. Ive seen them side by side last weekend at the sfla epic meet and I guess they need to be compared closely to see the differences. I have the SURE mount and its great. I even pulled my SU mount to replace it with the SURE mount 2 weeks ago.
BTW...look at the CPE TMIC....it looks very similar to the SU TMIC that was offered quite some time ago. So for you to make such a broad statement about the products being copied would be incorrect IMO
