Hey Guys and Gals.....I am here to tell you its not the easiest thing to do.....BUT...not the hardest either....
AND its NOT necessary to spend any money on special tools you MAY only use once, even if they are only $5...that is $5 I can spend on something else...
NOW....I have heard guys talk about just using a coat hanger (which I did) and making the TWO pieces and go for it....BUT I descovered ANOTHER tool that makes this whole process even easier.....an extra set of hands (another person) would also help...but I did do this alone.
You will see at the bottom of this post a picture of the home made tools with their deminsions.
the first thing you do is remove the little side panels on the sides of the units fact to expose the holes which the tools fit into....you will see that there are THREE holes on each side....the top and bottom holes which are round...and the ones between them which are oval or oblong.
Insert the two "U" shaped tools, one on each side, into the ROUND holes and push then in till you can feel that they have gone under the clips which hold the unit in.....THEN
take the LARGE tool and insert each end into the oblong holes, one on each side......install it so that its INSIDE the other U shaped tools....
NOW, while pushing/pulling the U shaped tools to the side (this FULLY disengages the clips), pull out on the LARGE tool to remove the unit.
the whole thing is in there pretty snug....it took a bit of fiddling for me to do this alone...but with a second set of hands so one of you can operate one tool while the other pulls the unit out....would greatly ease in the removal.
hope this helps some of you out.
