Matthew said:to post this which is inn the other thread (keith i tried to call friday but your office is closed the enitre end of the month, and im trying to get this worked out before the weekend)...
I hooked up the multimeter to the ground and also to the ECU side of the clamp runnign to pin 60. At idle and out of boost it shows .02v, and upon entering boost goes up to only .07v, with it spiking from .08v-.09v at like 6k RPM in 3rd gear. otherwise for the most part it puts out .07v...
yeah, I know, I did even triggered the clamp FULL TIME, and the ECU was still pulling fuel. HOW??? I DONT KNOW...no clue yet as of today, because I dont have the 2nd O2 installed...WHERE THE HELL IS SEEING THE FUEL???Matthew said:the sensor is def bad im trying to get a new one. i need an answer to this:
" that doesnt make sense. if the clamp is passing through a volt of .09 why is the ECU pulling fuel?"
I've been there before....many times...accept I wasn't going to the track. Our ECU's. WTF?igdrasil said:yeah, I know, I did even triggered the clamp FULL TIME, and the ECU was still pulling fuel. HOW??? I DONT KNOW...no clue yet as of today, because I dont have the 2nd O2 installed...WHERE THE HELL IS SEEING THE FUEL???
it sucks...
think about this, it happened to me one day I was going to the tracks, spend ALL DAY tunning and inspecting everything in place, then when in route to the tracks, suddently the car starts to lean out....and I was WTF!!, while still on route....I even added so much fuel to the point that the car stalled!!!!!! and nothing, lean lean until 5000rpms aprox then it bogs down.
you see???acidbbg said:Yeah..i had these same problems not to long ago...I remember one time..as i was on the way to the track...i was fine tuning..my nitrous map...and the car started to pull fuel like a mofo..I put huge number into the mpi software...and still didn't matter..it would lean out..
I reset the ecu and loaded my daily driver map..and the car ran rich...not sure what happened..and haven't had any time to try & retune my nitrous map..
mathew are you still running no extra injectors?
Chas
sorry its my english...Matthew said:i dont understand what youre saying about the o2...
