2003speeds
- 2003 Spicy Orange Mazdaspeed Protege
I am in need of some help with an issue I have had with installing my SS AFC PSC1-020E for the Mazdaspeed Protege. I am not able to get my computer to connect with the ECU (the error message says not able to connect to the ECU). I have the 9 pin serial to USB and have installed the prolific Serial to USB driver (I am running Windows Vista), but when I put the car to on (not running) it seaches for the ECU connection and then the R4 program freezes while Windows is telling me to close the program. (I am using the correct port as well)
I know I connected everything correctly, but I just cannot get the SS AFC to connect to the ECU. I am thinking the AFC unit works since my car runs fine with it still wired up.
(If the SS AFC unit didnt work while still connected, would my vehicle even run at all?)
Is there any tips you may have on how to get this to connect to the ECU? I checked all connections and soldered everything. I just for the life of me can not get this to connect to the SS AFC.
Thanks,
Nathan
Thanks,
Nathan
