Springs???
i'm not sure what adding springs to your car has anything to do with your dancing abilities but sure, doesn't hurt
no you do not need new struts. You should get an alignment after installing new ones though. Your toe will be off for sure
the stock ES struts will blow out with aftermarket springs, but the MSP has better parts, so they can take the abuse
at least for a little while, depending on the driver
