Spark issue, help!
DeeAOne
i have a sohc b6. the issue is that sometimes i get spark and sometimes i dont. i know its not the coil because i replaced it and it did the same thing...so its before the coil, whatever the problem is. i will start it and sometimes it will run for half an hour or sometimes only 5 seconds. and then it wont start again until i unplug the coil or wiggle the wires. i have replaced the clip too so i know its not that. if anyone knows please help. thanks!
Could be your pickup in the distributor. I know that sometimes can cause an issue. Also have you checked your cap and rotor???
