Today, after washing and drying the car I had a surprise waiting for me.
Found a little rust spot under the car, where the body meets the chassis. Likely caused by a stone chip.
It had already started spreading a bit under the paint.
Here is how I repaired it.
Sorry, i forgot to take a picture before I started sanding.
So, as you can see, I removed the "dead" paint and sanded the area.
I then, sprayed brake cleaner all around that area just to remove any oils, wax or anything that could prevent the undercoat paint from sticking.
I got some undercoat spray - VERY thick black spray.
This one is written in japanese but I am sure you can get something similar where you are.
Then I sprayed a thin coat first, just to creat adhesion for the the second and third thicker layers.
The photo was taken after the third coat, while still wet.
I did this on the other side too - albeit without sanding as there were no stone chips or rust spots.
I will most definitely get mud flaps installed next time I take the car in for a service.
Hope it helps.
Sent from my iPhone using Tapatalk
Hope it helps.
