Ross bars for roof rack, who's got'em?
Cx-9
Thinking about getting a set of these. Anybody have cross bars on their roof? Factory or aftermarket, how do you like them?
I already have the roof rails installed just need to cross bars.
Dealer wants $200 but looks like I can save 25% by getting them through Amazon
Mazda CX-9 2016-2017 New OEM Roof rack cross bars 0000-8L-N11 https://www.amazon.com/dp/ (commissions earned)
joeeey
2019 Mazda CX-9 Grand Touring
I purchased a OEM set from eBay for 173.00 shipped. Installation took about 30 minutes. OEM is the way to go. Aftermarket looks very bulky, OEM looks sleek.
MattGoose
CX-9
They are fine. Installation could be, should be, easier. But if you get the ratchet extension they recommend, it's fine.
They do make enough noise that I wish I could pop them off when I take the Thule off.
SK77X
Contributor
2016 CX-5 GT, 2017 CX-9 GT
I agree with both of these posts. They're definitely the way to go in terms of sleekness. I negotiated to have them included and installed when I purchased the car because I had read about the install being a bit of a pain.
And I too wish I could easily take them off when I'm not using my roofbox because with the moonroof shade open you can hear some wind noise if you don't have music/radio on. But beyond that, they're great!
Mazda CX-9 Grand Touring 2016
A Wiha 36236 T30 ball end Torx screwdriver makes it easier to get the screws in & out. I guess they made it difficult to get the screws out to deter theft of the rack and whatever is on it.
2019 CX-9 Signature
I got the factory bars from ebay. Install was not hard but took a while with the tool that came with it. My front bar is a little loose by the sliding joint. Got to go back and see if I could make it tighter.
Should that sliding joint be allowed to slide? If you have a load on the bars, drive over a bump, the load will flex the bars. Allowing the slip takes the side thrust off the roof rails.
2019 CX-9 Signature
I'm not sure about this. The rear bar feels firm and no movement but the front has about 1mm of wiggle room at the joint.
Cx-9
I purchased to oem cross bars from mazda swag. Couldn't be happier. Tho they area a pita to install
2018 CX9 Sig
I have the OEM cross rails, negotiated at time of sale including installation. I heard they were a bit problematic to install, therefore I will not be removing them anytime soon.
Peace and blessings,
Azeke
Latest posts
