Hey All,
The reason why I came here.. I need to re-wire my Radiator Fans. For some reason, they're both hooked up to the blower motor... so, If i want to pass emissions, I have to have it turned off, problem then, is that it tends to overheat. So, I need to figure out how to hook it into a manual switch atleast to pass emissions atleast.
So, here is the closeup of what i'm looking at
On the left, you'll see it's wired into some relay. I would think that it would be wired into a relay switch that's tripped when the temp sensor tripped, but it's not.
So, I guess i'm trying to figure out what else i can link that into, or wire it into its own component, and build my own relay switch for it. (Something like this: http://autospeed.com/cms/article.html?&A=2477 )
I think at this point, I just need to figure out what to hook the power/ground up to.. (blue black is power, black i ground) and then link that thru to a switch. I also need to check the voltage on them.
If anyone has any thoughts on this, i'd really appreciate it. I'll post my howto when i get it done.
~DocNasty
~DocNasty
