Revs drop to zero when I go full throttle and push Clutch in
So I know I have a boost issue where I can't get past 3.5 psi. The waste gate is fine and I can't find a vacuum leak. The other day I was driving and noticed while I was passing a truck I down shifted and went into 5th but I didnt let the clutch out right away. I noticed that the revs went to zero then came back up to about 700 rpms, the car didn't stall and it doesn't matter when I shift it does the same thing, the only thing I noticed is that it only happens when I go all out and not when there is a steady climb.
Mods are:
Hard pipes
Forge motorsports bpv
ATP wastegate( I know not a mod but I did replace the wastegate)
Perrin MBC
Turbo timer which isn't working since the intercooler fan stopped working
I was gonna ask if you have a blow off valve thats atmospheric are you sure your recirculated and thats its well adjusted ?
It's a vac/boost leak fosho. Check to see if any lines may be damaged or connections loose
It's an atmospheric bpv I am thinking about getting a tunin kit for it since I'm using the set up that came with it, going to use the spring for 5-10 psi. Are there any obscure vac lines that aren't that visible. I took apart every vac line I could see and didn't find anything, I also used carb cleaner and didn't notice any change in idle.
So does that mean I have a leak before the MAF?
no,when air enters your engine through the filter it passes thgough the MAF before entering the turbo.
then travels through your intercooler and pipes and into the intake manifold.
in stock configuration the BPV puts the air back into circulation between the turbo and MAF. there for there is no loss of air that the computer thinks the engine is getting.
when you have a VTA setup with a stock configuration, you lose that air air that the MAF registerd.
the search button will help you greatly.
figured i would help a little though.
Ok I see what you are saying so would it be better to go back to the stock bpv setup or is the btw ok to use. Also I hate search buttons on forums never really get an answer tried google though but every car is different, I greatly appreciate your help.
Run the stock Bpv and your VTA together... That's how I'm running right now... HKS Ssqv works fine
I have a relocated MAF with just an HKS BOV, without the stock BPV and the car runs great, never had a single stalling issue.
