Review: HSV GTO Coupe
mikeyb
Contributor
01 BMW 325xi Touring
Plough Your Own Road
Bill McKinnon 10/02/06
www.drive.com.au
It may be an old-tech tractor but this brute can still put a smile on your face.
For: The V8, the V8 and the V8. Tidy, athletic dynamics for a 1700kg coupe. Luxurious driver's seat. Works nicely as a long distance drive. Good rear-seat space for a coupe. Strong brakes. Well equipped. That body.
Against: Minimal boot space. Space-saver spare. A few rough edges on the fit and finish front. Interior doesn't quite feel like $80,000 worth. Clumsy rear-seat access and passengers sit under glass.
Rating: 4 Stars Out Of 5
Holden has now returned the Monaro badge to the family glorybox - for the time being - but the car itself is still being built in left-hand drive form for the US market, where it's named the Pontiac GTO.
Holden Special Vehicles will continue to produce a right-hander, with the same acronym on its side skirts, for the home market until the middle of this year. HSV's GTO coupe costs $78,990.
The company has exclusive Australian access to the Chevrolet 6.0-litre, 297kW LS2 V8, which we last covered in our HSV Senator test.
The regular Holden V8 is now also a 6.0-litre but that is another version. It produces 260kW, the same output as the last iteration of the 5.7-litre LS1 used in the 2004-2005 Monaro.
The LS2's 297kW is produced at 6000rpm and its 530Nm of torque peaks at 4400rpm. The 6.0-litre uses a larger bore than the LS1, a 10.9:1 compression ratio and a 6500rpm redline. The cylinder heads are derived from the Corvette Z06.
A Tremec six-speed manual gearbox is mated to a Corvette clutch while the Turbo Hydramatic four-speed auto soldiers on.
Brakes have Corvette-type twin-piston front calipers and wheels are 19-inches, with 245/35 Pirelli P Zero Rosso tyres.
The LS2 has grunt and power everywhere. It just goes to show that old-tech - pushrods, single cams and two valves a cylinder - still works if you make the cylinders big enough.
More than 87 per cent of its torque is available from 1600rpm, which corresponds to 100kmh in sixth and it will effortlessly pull this gear from just 1200rpm. Mid-range performance is characterised by a pure, no holes delivery, seemingly endless elasticity and exceptional smoothness.
On a tight road, you can just stick it in third - which will take you from 10kmh to 160kmh - and drive it like a tractor. A very quick tractor.
As it moves into the top end, the 6.0-litre begins to hammer out its 297kW with a harder edge and a meaner, more rasping note but it remains acceptably smooth. The 0-100kmh sprint takes five and a bit seconds.
As expected, the six-speed manual has a relatively heavy action but it's quite obedient, apart from a clunky first to second shift and an occasional reluctance to go into reverse. You can hear the gearsets meshing when trundling along in traffic. Call it character.
The long-throw clutch is fine but those with shortish legs will have to sit close to the steering wheel to get sufficient leverage on the pedal.
Given that it's a big, heavy lump, the GTO is remarkably nimble and responsive in tighter bends. Body movement is efficiently checked when changing direction quickly and the car's attitude is easily adjusted with the accelerator.
This is a machine that expects you to exercise control and rewards skilled, attentive driving with fast, enjoyable point-to-point performance. It is not sanitised, or anaesthetised, by protective technology: if you make a big blue you'll be bitten. Hard.
The steering, though heavy when parking, is progressively weighted and reasonably tactile at higher speeds.
The Pirelli tyres stick OK but squirm and squeal a little when you're still some way from the car's dynamic limits, especially at the front. They also seem to detract slightly from steering precision and feel compared with the Bridgestone tyres sampled on the standard Monaro and other sports Holdens.
The suspension generates a firm-verging-on-hard ride in town but becomes more compliant and GT-style comfortable on the open road, remaining so as the surface deteriorates. The GTO is a lovely touring car.
Brake pedal-feel, progression and fade resistance are OK, although bigger brakes would be welcome.
The GTO's cabin is almost identical to the Monaro, apart from HSV instruments and a few other touches. It maintains an attractive, purposeful GT character, though for nearly eighty smackers a bit less fake metal and some more real stuff - on things such as the door handles and gear lever - would be appropriate.
Standard equipment includes a trip computer, a six-disc in-dash CD player, leather upholstery, front/side airbags, automatic air-conditioning, cruise-control, power everything, rear parking sensors, HSV floor mats, Data Dot security and an electrochromatic rearview mirror.
The power-adjustable driver's seat is properly bolstered and luxuriously comfortable on a long drive. It has three memory settings.
Seat travel is generous and the steering wheel is height and reach adjustable. Some tall drivers may want greater headroom. Vision is good for a coupe.
Rear-seat space is also generous by coupe standards and the seat is supportive and comfortable. Access, though, is tight and tedious, as the driver has to stand beside the car holding the front seat while it slowly moves forward, then back again. The seat position then has to be reset with a memory button.
Headroom is adequate up to 185cm, though passengers sit under glass.
Boot space is tight, a consequence of the US requirement to relocate the original Monaro's fuel tank ahead of the rear axle. A spacesaver spare is underneath.
If you're a lover of V8 muscle cars (guilty officer) the HSV GTO is great value. It's a loud, fast, blunt instrument - petrolhead heaven, basically - in a body that grows more beautiful with age.
However, if you regard V8 muscle cars as overpriced, inefficient, luridly decorated agricultural implements, well, we can understand your point of view. You sook. Go polish your Camry.
Vital Signs
Country of origin: Australia.
Engine: 6.0-litre, 16 valve, fuel-injected V8.
Power: 297kW at 6000rpm (above average).
Performance: 0-100kmh in 5.3 seconds (quick).
Brakes: Discs with anti-lock and EBD (good).
Economy: 9.5-11 litres/100km highway (average), 18-25 litres/100km city (premium unleaded; thirsty).
Prices: Recommended retail $78,990.
Street price: $3000 off.
Main options: Sunroof $2600.
Warranty: Three years/100,000km (average).
Residual value: About 48 per cent after three years (below average but this should improve now that the Monaro has ceased production).
Safety rating: Not yet tested.
Alternatives
Ford FPV GT
Ford has no BA coupe but in character the GT-P is similar in some ways to the HSV GTO. Weight hurts it though and the 290kW, 5.4-litre V8 lacks the sheer muscle and responsiveness of the GTO's Chev LS2.
Chrysler Crossfire SRT6
Lives or dies on its looks but underneath it's mostly Mercedes hardware from the pre-2005 SLK roadster, so it's competent. Supercharged 3.2-litre V6 produces 246kW. Goes like you know what off a shovel.
Nissan 350Z
The Z's value-for-money deal is very attractive. The 3.5-litre V6/six-speed manual now produces 221kW (206kW with the five-speed auto). Loud, raw and loaded. Take no prisoners Track version is $67,990.
