TurboGoKart
2000 Protege LX, 1.6L. I wa having a bad oil leak, aka 2qts a week so I replaced the front main which is where it seemed to be coming from. While I was in there I replaced the timing belt and water pump as well. Today I'm bleeing the coolant and for the first 10 mins of the car idling it was leak-free. Then all of a sudden it starts leaking lots of oil from near the crank pulley. I will take off the timing covers tonight or tomorrow to figure out better where it's coming from
My question is, how far does the seal need to be tapped in? Flush with the aluminum case or all the way in? Are these seals pretty finnicky in that if you don't get it seated just right it will leak? Thanks for the help!!
