I am getting ready to replace the head unit on an 08 Mazda5 and wanted to find out the following questions if anyone knows the answers.
Will the clock on the lcd continue to work or will that go with the radio unit?
How much room is there in the dash after a six cd changer is removed, enough to find somewhere to put in a pac-swi box for steering wheel controls or should it be placed somewhere else.
When wiring the pac-swi is there any way to get it hooked up via the harness or do i need to cut the factory control cable before the connection?
Thanks in advance for any help you can provide
