Removing the MAZDA 3 from the truck
racenut
Removing the MAZDA 3 from the trunk
HI, I just got an 08 i Touring with the 2.0. Is the MAZDA 3 lettering on the trunk just stuck on or is there holes behind it?
THANKS
racenut
or just pull it off with your fingernails. worked for me. didn't need any of the high speed low drag fishing line, or string or hair dryer or lubricant.
If you get any left over glue, just wet it with some water and rub it off with your finger.
ok, before you do this, i have an '06 and i took this off to get rid of the "3" and just leave the mazda part. And it was a good thing i did because there were two pegs in it to make sure that it was stuck on correctly. As well, i would not suggest using your hands. Use fishing line and a hair dryer. It works a lot better.
