Rear sway bar bracket replacment
02 Mazda P5
Other then the stock oe brackets, what other option can i go. Stock bracket are kinda pricey at the dealer what did you all use or recommend.
I had to replace one of mine a year ago. I got it from awrracing. They didn't have them, but they sourced them for me. They said they were going to start making them. It was $60 if I remember right. I'd give them a call
I have some energy suspension bushings and brackets you can use, they are brand new and I bent the brackets to fit but ended up buying a new stock bracket instead. Will probably require a dremel or something to elongate the holes a bit but they are wider than stock and should fit.
