The vac line should run off the port on top of the intake manifold to a T fitting, one of the lines off the T runs to the bypass valve, the other runs to the wastegate. The boost gauge should be T'd off a different vacuum line on the intake manifold, avoid running too many sources off the same vac line. A vacuum block on the brake booster vac line is really the way to go so each source can get the same vac reference.
Would any vacuum source on the intake manifold work for my boost gauge?
I don't know which one to cut and split off.
Any possible photos perhaps?
