Radiator has pinkish gunk, I am terrified.
Sepurb
2006 Mazda 6
first and foremost hello and I appreciate that u can register on a Treo, LIFESAVERS!!!
anyway I have a 2006 mazda 6 and over the past week and a half the temperature gauge has fluctuated from Normal(needle in middle) to HOT. I noticed the scent of coolant but I was told that since it calms down I would be ok until I discovered the problem. well over time I realized that it had been SPEWING antifreeze due to the mess covering the motor.
I added water 2 the reservoir and replaced the ruined radiator cap, albeit with a 92 accord cap, and the problem was still the same. well wednesday the car was going uncomfortably close 2 "H" and I asked more quasi-mechanics what I should do and I was told again 2 add water 2 the reservoir and try 2 maintain the Normal temp. well @ about 11pm I went outside with a half filled gallon of water 2 add 2 the reservoir, I noticed that not only was it plenty of fluid that resembled a pink & green fruitcake but also that the inside of the radiator was practically insulated with creamy whitish-pink gunk. man I have no clue what's going on but I really don't want 2 crank the car & I may take off from work 2moro. please help!! if this is the wrong board I apoogize greatly!!! thanks in advance.
Sepurb
The molecular components of coolant break down over time due to heat, contaminants, etc. It is important to check the coolant colour at least annually (with a cool engine, remove the coolant reservoir cap and use a coolant tester to check the colour and quality). Coolant normally goes in green or pink with the consistency of kool-aid, but after 5 years or so it will darken a fair bit and get thicker as it captures contaminants in the cooling system.
Make sure you get a flush and fill when you get the coolant changed, not just a drain and fill. The coolant can't hang onto all of the contaminants in the system and they build up over time. A flush gets rid of most of them, preventing blockages, leaks, etc. - all of which can be very expensive to fix later.
