Hi, have a 2016 CX-5 GT with Tech package and iActiveSense. Wondering if anyone is using a radar detector with it - specifically wondering if the radar will set off the detector (which is a problem with some Audis, for instance).
I don't have a '16, but a '15 with SCBC radar, and my V1's radar gets interference. I had to sacrifice it and turn it off. Me personally, I never need it in my area, and if I did get zapped with radar, it would probably be too late anyways(unless someone got zapped ahead).
What kind of bands are in use in your area? K or KA band?
In LA it's mostly the KA band is in use and I have disabled the K band, no false alarms from other sources. I have the Escort Redline.
I have installed mine, above the mirror with a custom bent aluminum sheet. No drilling required. Mine is the Redline which has a Magnesium case, not detectable by law enforcement. Not sure if is legal or not in your state to have a detector.
In LA is legal, so no need for special detector.
By reading on detector forums, the conclusion is to get at least an Escort class. The best that you can afford basically. At least the 8500X.
http://www.rdforum.org/showthread.php?t=41593&p=550584#post550584
I can even mirror my phone's Escort app on the Kenwood, that I have installed.
Any pics of your install? I have a Redline which I hardwired in my other car; it is hidden behind the tint strip. With the CX-5 I don't have a tint strip (I know I could get one) and I don't know if I have the motivation to hardwire another RD. I know the Solo S3 is not as sensitive, but it sure would be more convenient, especially with two other cars in the family.
A radar detector is simply a receiver, it doesn't transmit so is legal to own and use in your car in every state except backwards Virginia. They are also illegal in Washington DC and on military bases.
I have two of these (Escort 8500's) and use them all the time. Very excellent!
SCBS is actually a laser. So are most police detectors now. In some applications these are referred to as LIDAR. V1 has a laser detector so it would see the bounce off an object, exactly as the SCBS laser sensor does.
Some of the other systems do use radar for more afar monitoring, like blind spots and the cruise control/forward object warning.
http://www2.mazda.com/en/technology/safety/i-activsense/ explains and, handily, gives the frequencies you can use to check with your detector.
There must be some amount of EMF emissions put off for a device like this to pick it up.
http://www.stalkerradar.com/spectreRDD.php
On a side note...I thought I remember reading a C&D article years ago on ways to reduce range that a LIDAR gun could pick you up. Bright headlights on and reducing the reflectivity of the license plate. Of course... that is probably the primary reason for the front plate requirement in our state.
In early 90's a friend had this little black box with a red LED on it that would set off X&K bands on radar detectors. I think he got it out of of the back of Popular Science. It even included a game with a points system base on reaction time to tail lights being activated. I think they got pulled from the market years later or perhaps weren't legal to begin with.
EDIT: IIRC device was called the "Highway Zapper"
