quick question: 6.75"
The best thing to do is open your door up and measure the diameter of the opening. If it is 5 1/2" or larger you are all set. While you have the door panel off double check the mounting depth too. Open and close the window and make sure a speaker that is 2 7/16" deep won't hit the window.
