I have a spare head for my FS 2.0 thats been sitting in my basement for some time now waiting to become a part of larger long term plans for the Pro. Im planning to install mazdaspeed intake and exhaust cams into it, and had also considered skimming the head down (maybe 0.020- 0.030) and using a 20 thow head gasket to up compression (without having to break open the bottom end).
My questions are as follows:
1. Considering the increased lift and duration of the mazdaspeed cams, at what point are my valves going to start hitting pistons (that is to say, should I skim the head/ utilize a thinner gasket at all?)?
2. Along wit the cams I had also planned to add; adjustable cam gears, and upgraded valve springs, but was hoping to avoid the expense of upgrading my valves. Is it really necessary to move to SS or titanium valves when using more aggressive cams (i.e. revving to moderately higher RPM)? I realize its a good idea, but is it necessary in the case of the FS?
