Questions about mods
kwjhduibd
01 Mazda Mp3 *turbo*
i am about to begin a huge purchase of some mods for my P5 from SRmotorsports
i was going to order the mazdaspeed exhaust, cams , underdrive pulleys, also get an injen intake system, short shifter , and a suspension of some kind *still deciding on suspension* being that i just got the car will doing these mods null my warrenty? also if i am planning on doing the turbo kit for the P5 should i waste my time with these mods i will admit the turbo kit prolly wont be until the new year or a lil after but still a bit away. also will the hp gains be noticed for the money i am putting out??
thanks for the help
Wow...so much to answer. Honestly, start with a search...all of your questions have been discussed at length a few times.
I'd say if you're thinking turbo, I'd wait on most of what's on your list. You'll be taking off a lot of your mods when the turbo goes on.
Most of those mods give very small returns anyway.....wait for the turbo. :D
but what would have to be removed just the pulleys wouldnt cause the turbo kits doesnt come with cams and would work witht he aftermarket cams correct also iw ould have to drop the intake cause for obviouse reasons
dealers must prove the mod itself caused the problem to deny warranty.
that being said, with those mods if you get engine, tranny, or suspension problems you will have a hard time or it probably won't be covered ;)
id just say injen and the exhaust would be replaced if you got a turbo. (though you dont HAVE to get a new exhaust...)
you can get a lot of those things cheaper...for example, i believe the injen intake is cheaper from adventon.com
