Question about Cobb Tuning
jdw1
07 speed6
Hey guys, I had a mechanic tell me with an intake you will run lean and potentially burn up valves so he recommended Cobb. Is that true and are their any cheaper fixes?
Is that your only mod? If it is, the ECU should be able to compensate and you're fine.
make sure to reset the ecu by taking off the negative terminal for about a minute. Then on the next startup after the battery is re-connected, leave the ignition on but car not running, the check engine light should blink 8 times i believe, this will mean the car has now started to learn a fresh tune.
