Ive been looking at the E manage as an inexpensive means of adjusting fuel, and a quick search has shown me that a few other people around here are already utilizing the Greddy unit. But, after reading some info on the E manage unit on the Greddy web page Im a little confused. The E manage apparently alters MAF signal in order to adjust fuel, I thought this was a non-valid option for the Protg as altering MAF messes with ignition timing, and is no good for closed loop operation (when the ECU switches over to calculating fuel addition based on O2 sensor signal)?
Also, Ive heard that the Protg will eventually learn around a unit that simply alters MAF signal? So how are people getting this piece to function adequately, when apparently it should be susceptible to all the same problems that make the SAFC a poor choice for a Protg application?
A few more quick questions: The 2L Protg has a 0 5V MAF sensor correct? Does the voltage output increase or decrease as flow increases?
