Protege 2.0 Race header - No Longer Available
Stainless Steel 304 / 4 to 1 Racing Header with 2.0 merge to 2.5 exhaust collector outlet. Brand new , never used.
1.750 X .065 304 Stainless , Tig welded. Included are the correct lower mating flange and do nut style gasket to adapt this to a street vehicle exhaust system.
List Date: 5/31/2015
For more info, click here to view the original listing: Protege 2.0 Race header
This item is no longer available.
********************/analytics/ga/mazdas247
Was this originally used on the higher compression race engines? Also where are you located?
Yes it was but this was at the beginning of the Life of the Protege running in World Challenge. The tube diameter is the same as what we used on our street header. This unit could be modified to fit the OEM exhaust system.
