Power to Side Mirrors, Cig Lighter, and Radio??
mctriple
Hey guys. I was driving home from work tonight, and I had noticed that I hadn't used my iPod (powered constantly with an inverter hooked up to the cigarette lighter) in a week or so, so I decided to unplug the inverter from the cig lighter. It didn't want to come out easily, and when it did come out, the entire lighter assembly came out. After a minute or two, I noticed that my radio was turned off and won't come back on. My inverter is also now unable to receive power through the cigarette lighter. The last thing that I've noticed is that the side mirrors, which are powered, do not work. I believe that is everything that is wrong. I tried looking behind the cigarette lighter (took out the ashtray which helped visibility) and around from the sides, where the feet go on both driver and passenger side. No wires look like they were torn out of place.. everything is secured to their locations with screws, and there are no stray wires dangling anywhere.
Does anybody have any idea what could have happened? I really didn't pull on the lighter THAT hard. It popped it out of the plastic, but that's happened before.. it's never been very solidly fitted into the hole.
I just have no idea. Everything was working fine, and I didn't NEED to unplug the inverter, but figured I might as well since I haven't been using it lately. What a disaster to come out of trying to be prudent.
...a fuse? its possible it could pop a fuse if the plugs wires/connections accidentally touched metal when you removed it. You didn't say if you checked that, so try there first. under the dash at the drivers feet is where it should be. The power mirrors would be on a seperate fuse from the radio, not sure why they wouldn't work.
