spotthedogg said:
I would like to see about 5-8% reduction in RPM on the highway and have been searching for an option. I thought I read some where that the 2.0 626 5th would drop in? Also something from nsn
http://www.nsnmotorsports.com/produ...d=162&osCsid=06377328fd9b881f4a44533de6dec90e
I really want to change this when I do my clutch/flywheel/LSD(ughdance)
Yessir, I found the 1989/90 626 or MX-6 non-turbo gear should do the trick. (Also 1st gen Probe SE I think and escort/Tracer w 2.0L) Here is a bunch of info I have been uncovering over the past several days. Somewhere between 1:0.71 - .72 is where I want to be. Sorry it doesn't flow, these are all cut and pasted from all over the net.
EscortTransmission
Mazda based G-series transmission(G5M).
1st - 3.310
2nd - 1.830
3rd - 1.310
4th - 0.970
5th - 0.750
Final - 4.10
Probe SE Manual Transmissions: 2.0I4 engine
1st: 3.307
2nd: 1.833
3rd: 1.233
4th: 0.914
5th: 0.717
rev: 3.166
Final drive: 3.850
Protg 5
G15M-R
Used with FS-DE, FS-DET
Type 5MT, FWD
1st gear 3.307:1
2nd gear 1.842:1
3rd gear 1.310:1
4th gear 0.970:1
5th gear 0.755:1
Final Drive 4.105:1
Reverse 3.166:1
Differential open, 2 way LSD in FS-DET
Shift mechanism remote, rod actuation
MTX
2.0L FS
First gear
3.307:1
Second gear
1.833:1
Third gear
1.233:1
Fourth gear
0.914:1
Fifth gear
0.717:1
Reverse
3.166:1
Final Drive
3.850:1
Ford Five Speed Manual Transaxles
Trans Model First Second Third Fourth Fifth
2005 Escape 3.50 1.94 1.26 0.95 0.81
G5M 3.307 1.833 1.311 1.030 0.795
G5M 3.310 1.830 1.310 0.970 0.750 (Probe2.5L/Escort ZX2 2.0L)
G5M-R 3.666 2.059 1.310 1.030 0.837
G15M-R 3.307 1.842 1.310 0.970 0.755
iB5 3.154 1.926 1.281 0.951 0.756
M5 3.45 1.94 1.28 0.86 0.69 (Tracer 2.5L, Festiva)
M5 3.30 1.83 1.31 1.03 0.79 (Escort/Tracer 1.8L)
M5 3.42 1.70 1.15 0.87 0.73 (Escort/Tracer 1.9L (FS))
M5 3.42 1.84 1.29 0.97 0.73 (Escort/Tracer 1.9L)
M5 3.31 1.83 1.23 0.91 0.72 (Probe/Escort 2.0L, 2.2L Non-Turbo)
M5 3.25 1.71 1.19 0.93 0.71 (Probe 2.2L Turbo)
M5 3.250 1.90 1.32 0.98 0.71 (Probe 3.0L)
MTX 3.416 1.842 1.290 1.028 0.820 (Capri Non-Turbo)
MTX Q 3.667 2.136 1.448 1.028 0.767
MTX G 3.307 1.833 1.233 0.970 0.795 (Capri Turbo)
MTX-75 3.667 2.136 1.448 1.028 0.767
MTX-75 3.42 2.14 1.45 1.03 0.77
MTX III 3.60 2.12 1.39 1.02 0.75
MTX IV 3.60 2.12 1.39 1.02 0.77
Mazda Five Speed Manual Transmissions
2003 MAZDASPEED Protog 3.307 1.842 1.310 0.970 0.755
2003 MAZDA6 i 3.307 1.842 1.233 0.914 0.733
2003 MAZDA6 s 3.153 1.842 1.258 0.947 0.733
5MT 3.136 1.888 1.330 1.000 0.814
M5OD-R1 3.720 2.200 1.500 1.000 0.790
M5OD-R1HD 3.400 2.050 1.310 1.000 0.790
G15M-R 3.666 2.059 1.310 1.030 0.837
the F2-SOHC G25M from the 89-92 probe GL/626/MX6 NA has some impressive ratios! 1.233 3rd -- .927 4th -- .710 5th
I like those! When used with the 4.3 final drive should work out to good acceleration with a decent top speed
the 1G G25 has the same 1st gear as us..
that box has:
3.307
1.833
1.233
0.927
0.717
essentially the 2.2 NA has the exact same gearing as the Probe 2.0, including 4.105 final. even though the 1-2 ratio change irks me every time, i figure with a lower 3, 4, and 5 than we have now, it would go more unnoticed, as well as allow for those gears to hold longer. this is what I've come to terms with.
As for G-series, I've done lots of research on them. Here is a break down of the cars they come in:
87 323 GT (cable operated)
88-89 323 GTX
90-94 Protege LX
91-94 Mercury Capri (cable operated)
91-96 Escort GT, LX-E and Tracer LTS
95-98 Protege ES
93-97 Probe (all models)
93-97 626/MX-6 (all models)
01-03.5 Protege w/2.0 FS motor (not the 1.8 FP, they had F-series)
98-02 626 (all models)
98-present Escorts (all models including ZX2's)
94-???? Sephia's with 1.8 liter mazda motor. I think its 94-97, not sure
Thats about all I know of. There may be one or two more but not many. I'm not sure about the 2.2 naturally aspirated 1st gen MX6/Probe's F2 n/a trannies are listed as "g series" in the mazda factory workshop manua
but fifth was bad on the protege tranny so i used a 5 gear and output shaft from a 93 2.0 probe, and the 4.10 dif, input shaft, and gear clusters for 1-4 from the protege.
believe this to be the list of matching trannies:
87 Mazda 323 GT
90-94 Protege LX
91-94 Mercury Capri XR2
91-96 Escort GT, LX-E & Mercury Tracer
92-94 MX-3 GS (pos 1.8 v6)
93-97 MX-6 (both 4 and 6 cyl)
93-97 626 (both 4 & 6 cyl)
93-97 Probe (both 4 & 6 cyl)
95-98 Protege ES (1.8 dohc)
97-99 Kia Sephia (1.8 dohc)
97-present Ford Escort & ZX2's (i'm not sure of this but ppl tell me they use G-series too)
98-01 626 4 cyl (not sure about 6, i forgot if its a k-series)
01-03 Protege w/FS motor (2.0LX, ES, MP3, Protege5, MSP, and in 02' all DX and LX's got the 2.0 standard)
As for the changes under the small cover. I have seen 4 different 5th gear arangments on PGT/MX6 trannies. I wish I would have taken pictures of all of them because some were more heavy duty looking than others.
I mistakenly bought a 4 cylinder 1998 626 transmission thinking it was a V6 model (meaning the bellhousing would bolt right up. Luckily I found out that it is a G-series too and has the same taller gear ratios that I wanted
As for the synchro differences. I've done a bit of research into this as well. From what I"ve read on the Escort forums I've been on, the 97+ synchros in FORD models are updated (apparently by ford) for warranty purposes. I cross-checked part numbers between the old (90-94 protege lx trans) and the newer 626 2.0 transmission synchros and they were identicla. Which leads me to believe that the 97+ g-series in MAZDA cars had the same bad synchros that our V6 cars have
. But i'm not sure of the 99-03.5 protege, it might have had an update in its synchro design at one point, but I haven't cross-checked the part numbers yet.
just to throw my $.02, here is what I got directly from Ford:
Car...................1st.....2nd...3rd....4th.... 5th....Rev....FinDr.
2.5 2G Probe (M) 3.307 1.833 1.310 1.030 0.795 3.166 4.388
2.0 2G Probe (M) 3.307 1.833 1.233 0.914 0.717 3.166 4.105
91-94 Capri XR2 **Not available online...could get the book**
91-96 Escort GT, 3.307 1.833 1.310 1.030 0.795 3.166 4.105
91-96 Tracer
97+ Escort ZX2 . 3.307 1.833 1.310 1.030 0.795 3.166 4.105
Hello Scott
From what I remember you can use the taller gearset from a 88-89 Mazda 626 non turbo and it will drop the RPM by 400 in 5th gear.
Thanks
Derrick CorkSport
