P0302 after changing plugs and swapping coils (2011 Mazda CX-7)
Problem: P0302 Vehicle: 2011 Mazda CX-7 Steps taken so far:
  1. Replaced spark plugs
  2. Swapped coil packs to see if the misfire would move to another cylinder
  3. Added fuel treatment
The car had an extremely rough idle before the fuel treatment. Now the car has a very smooth idle post treatment (Seafoam + Techron).
The STFT is -5.5% idling and LTFT is 3.1%.
My theory is that there is a dirty injector or the misfire is due to the fuel system because the idle improved significantly after some fuel treatment which is not completely because I am still driving on the same tank I.e., I haven’t gone through all the fuel treatment.
The misfire is neither audible or physical, and I was very surprised for the code to come back after driving another for a day and a half.
Was the CEL on along with the code before you did the fuel treatment?
Did the code and CEL reset on their own, or did you clear the code?
Did the CEL come back on when the code was set again after the fuel treatment?
@BadMechanic Were you able to fix this issue?? I am having the same problem. 2011 Mazda CX7 grand touring with turbo. Misfire on cylinder 3. I've changed ugs and the coil pack. Please help!
