I've got a 2014 Touring AWD with 130k miles. Recently the Check Engine light is on and throwing a P011A code. I've done some investigating and know that there is a TSB for this - and I do fall in the VIN range. I have noticed that the heat takes longer to blow hot than before. I have also run some diagnostics using Torque and have the following after a drive - see below. What else can I check before bringing it in so as to eliminate any diagnostic fees from the dealer?
Freeze frame information:
Fuel Status = 0 byte
Engine Load = 47.843 %
Engine Coolant Temperature = 150.8 °F
Fuel Trim Bank 1 Short Term = -2.344 %
Fuel Trim Bank 1 Long Term = 3.906 %
Intake Manifold Pressure = 11.893 psi
Engine RPM = 1,724.25 rpm
Speed (OBD) = 50.952 mph
Timing Advance = 34 °
Intake Air Temperature = 55.4 °F
Mass Air Flow Rate = 17.42 g/s
Throttle Position(Manifold) = 23.529 %
Run time since engine start = 345 s
Fuel Level (From Engine ECU) = 48.627 %
Distance travelled since codes cleared = 13.049 miles
Evap System Vapour Pressure = 55.75 Pa
Barometric pressure (from vehicle) = 14.504 psi
Catalyst Temperature (Bank 1,Sensor 1) = 1,263.92 °F
Voltage (Control Module) = 13.915 V
Engine Load(Absolute) = 41.961 %
Commanded Equivalence Ratio(lambda) = 0.988
Relative Throttle Position = 13.725 %
Ambient air temp = 55.4 °F
Absolute Throttle Position B = 22.745 %
Accelerator PedalPosition D = 34.51 %
Accelerator PedalPosition E = 17.255 %
