I was doing an oil change yesterday and noticed that the insides of the front rotors were showing some grooves. Upon inspection the inside pads on both front brakes were down to the backing plates while the outside pads were only 25% worn. The calipers slide freely and the pistons retract just fine.
Has anyone else experienced this type of wear?
Not to be rude but I would like to save a lot of extra posts by saying that I am a brake system engineer so I fully understand all of the variables that go into abnormal wear.
I am just trying to find out if this is something others are experiencing.
However, if this is a common problem and anyone has any questions on what *usually* causes this type of thing I am happy to discuss. I just wanted to avoid the usual, lengthy "your brakes stop the car by sqeezing this thing called a rotor..." response
Thanks,
Alex
Thanks,
Alex
