OMG! Tier 2 Tune 280 HP 360 lb ft torque at the Wheel! Hold On!
AL Cx5
2024 CX-5 Prem Turbo Tuned Lowered Forged Wheels
Has anyone upgraded their DRTuned, turbo, to David's Tier 2 tuning? What was the tuning experience like and what is the final product?
David's Tier 2 has been in the making for three years. This tune should release more of potential of the turbos. I'm about ready to pull the trigger on his Tier 2 package. The Tier 1 package is very nice at low RPM. The engine is about to make spool up and make power and the ECU turns off the power. I understand the Tier 2 makes much more power, over a wider RPM range.
Looking at the dyno curves this tune is rocking at 3,500 RPM! David explains the Mazda ECU is not making nice on their chassis dyno. So the curve doesn't accurately show the power.
At this point, David is offering this to Tier 1 customers and will open it to first time users soon.
Maybe some of the CX-30 guys will read this and respond.
Gentle and polite suggestion to forum minders, may we have a Performance Forum?
DRTuned Tier 2
What is the issue on the dyno?
Newer cars are difficult to dyno. Traction control thinks it lost traction, the trans shifts when it's programed, torque management is a tangled web and so forth. Dyno operators learn how to trick the ecu and tcu on other platforms. Folks chassis dynoing Mazdas are few and far between.
I have standalone ecu and tcu on my race car. These make chassis dyno sessions a breeze. No traction control. My tcu has a dyno mode that turns off torque management and shift rpm. It will wind the engine to the moon. Unfortunately our Mazdas have rudimentary tuning features. Thus this is a big breakthrough for our platform.
David talks in vague terms but reading between the lines he has issues like above and probably others.
I have thought about that before. Ideally you want to dyno in a 1:1 gear but that isn't always possible due to speed or automatic upshifting, etc. So with the Mazda you can use a lower gear if the correct compensation is used in the dyno software. And there is a combination of driving mode, manual shift mode, and certain gears that will bang the rev limiter and not upshift. I know because it happened to me once and really startled me. I'll have to test it again.
That doesn't solve the issue with TCS though.
You have experimented with your settings more than I. After doing the initial modifications and tuning, we drive the car. It's rare we ever put the pedal to the mat.
We chassis dyno in 3rd gear, less than 1:1 so the wheel speed is not so high. We also can make a simulate 1/8 or 1/4 mile run on the dyno. Speed is approaching 180 MPH. We double strap for this set up!
We use the dyno as a tuning tool, not about peak HP but % gain. As they say, dynos lie, the track don't...
It would be nice if David took his car to the track and ran it stock, Tier 1 and Tier 2 and posted the time slips. THEN we would know how much the package gained.
I have the time, between race season, to tinker a bit on the CX 5 and do six logs for David to dial the car in with my mods. I need to get my wife on board. Her first reaction, this car zooms if I press the pedal down a little to far....:ROFLMAO:
Tier 1 IS so much more responsive than the OEM tune. Tier 2 should be a leap forward...
As you know, it's easy to modify past an easy to drive DD to a car that one needs to be vigilant or it will get away from ya...
I hope some other DRTuned customer is an early adopter and has experience with the Tier 2.
Oh and for dyno testing only, you can pull the ABS fuse to disable TCS. Just don't forget to plug it back in when you're done.
