But I just got an OEM 1WPE-14-302 Thai made Denso oil filter for my 2.5L last Friday from my Mazda dealer. Nothing has changed.I just reviewed the MAZDA CX5 oil filter part number and realize the the Turbo and Non turbo part numbers are the same now. 1WPY-14-302.
For the 2.5T, factory PY8W-14-302 Japanese Tokyo Roki oil filter found on the new CX-5’s has been superseded by the Thai made 1WPY-14-302 Denso oil filter only in the US market since Dec. 2019.Is the 1WPY a new version? Or did they change the recommendation?
Just tried mazdaswag.com.MAZDA SWAG SALES has the CX5 Ste and turbo oil filter listed as the same. Ed
Wow, this’s the most intensive comparison article between Japanese made Tokyo Roki oil filter and Thai made Denso oil filter! This make me feel like I want to get more Tokyo Roki PE01-14-302B oil filter for my 2016 CX-5 from partsouq.com in UAE after my stock of 23 Tokyo Roki PE01-14-302A’s collected few years ago have exhausted.Comparison of Skyactiv 2.5T oil filters
www.mazda6club.com
his conclusion to change the Thai filter every 2500 mi is just dumbComparison of Skyactiv 2.5T oil filters
www.mazda6club.com
Yea, I agree. Poor judgement. But that filter not having end caps and being made kinda like a fram makes me want to deviate from oem and use a wix 57002his conclusion to change the Thai filter every 2500 mi is just dumb
Without metal end caps on both ends of filtering element doesn’t mean the filter isn’t good. Both sides of element are glued properly on each pleat and they won’t leak. In fact the process of sealing this way on the side of element without metal end caps is more involved ($$$) than with metal end caps.Yea, I agree. Poor judgement. But that filter not having end caps and being made kinda like a fram makes me want to deviate from oem and use a wix 57002
Cheaper Mazda MV “Value Line” maintenance parts including oil filters definitely look inferior than standard Mazda OEM maintenance parts. Mazda dealers use “Value Line” maintenance parts simply is to save their cost. Don’t use Wix oil filter on your 2.5T as Wix offers only one oil filter for both 2.5L and 2.5T.When I went to my local dealer to pick up some filters for my 2019 turbo the parts guy brought out the MV filters and I told him I wanted the 1WPY-14-302. He said no problem and brought those out. He did comment there’s no difference in the 2 and mostly they used the MV. Maybe I should consider using the Wix next time.
Mazda has never published any data on its OEM oil filters other than some document saying the OEM oil filter used on SkyActiv 2.0L / 2.5L non-turbo engines is a high-flow oil filter and don’t use earlier version of OEM oil filters used by other Mazda engines or it could trigger the CEL. Wix 57002 oil filter claimed it’s designed specifically for Mazda SkyActiv engines before the 2.5T came out. and did release the specs. Some people used Wix 57002 data as the specs for Mazda OEM oil filter on the 2.0L / 2.5L. But Mazda used a diffrtent OEM oil filter for the 2.5T which was released in 2016. Wix hasn’t come out a new oil filter for it, but keeps using 57002 for the newer 2.5T. By using the common sense, if the 2.5T can use the same oil filter as the 2.5L, why Mazda would want waste money to develop another oil filter just for the 2.5T? The specs between the 2 OEM oil filters have to be different. But after-market oil filter manufactures with the “one-size-fit-all” attitude use only one oil filter for all SkyActiv engines as long as it fits. And BTW, the same after-market oil filter is also used by many other engines from many other car manufactures.Is it known what the difference is between the turbo and non turbo filters? Are filter flow rates, media area, bypass pressure, if used, and other data published? An oil filter does not seem to be an extremely complicated device and comparison should be easier than it is.
I’m happy sticking with the OEM and satisfied it will preform well but just curious. I recently replaced air filter and OEM looked far superior than aftermarket.
I would stick to an OEM filter for Turbo. Your question is %100 valid. Why should Mazda spend more money to develop a different filter for the Turbo while they could use the same filter that they have for NA.Mazda has never published any data on its OEM oil filters other than some document saying the OEM oil filter used on SkyActiv 2.0L / 2.5L non-turbo engines is a high-flow oil filter and don’t use earlier version of OEM oil filters used by other Mazda engines or it could trigger the CEL. Wix 57002 oil filter claimed it’s designed specifically for Mazda SkyActiv engines before the 2.5T came out. and did release the specs. Some people used Wix 57002 data as the specs for Mazda OEM oil filter on the 2.0L / 2.5L. But Mazda used a diffrtent OEM oil filter for the 2.5T which was released in 2016. Wix hasn’t come out a new oil filter for it, but keeps using 57002 for the newer 2.5T. By using the common sense, if the 2.5T can use the same oil filter as the 2.5L, why Mazda would want waste money to develop another oil filter just for the 2.5T? The specs between the 2 OEM oil filters have to be different. But after-market oil filter manufactures with the “one-size-fit-all” attitude use only one oil filter for all SkyActiv engines as long as it fits. And BTW, the same after-market oil filter is also used by many other engines from many other car manufactures.
Bosch ST3300 Oil Filter - Fits 2016 but won't work for 2017??
