New Product Release! JBR GEN2 Mazda3 & MAZDASPEED3 Adjustable Front Sway Bar!
JBR
Authorized Vendor
09' & 2011 MazdaSpeed3
Details:
The JBR Tru-Torsion Front Sway Bar Kit is one of the most effective ways to improve handling without negatively affecting ride quality or increasing NVH. It's 28.6mm in diameter and offers two settings to choose from that provide a 35% or 55%* increase in stiffness to resist body-roll. The adjustability allows for fine tuning and makes this sway bar kit the perfect choice whether youre already running a JBR Rear Sway Bar or any another manufactures bar.
The JBR Front Sway Bar Kit is CNC bent and includes stiff polyurethane bushings for instant suspension response. All of the necessary hardware is included making for a direct factory replacement while ensuring a perfect OEM-like fit. The bushing brackets also include built-in grease fittings to make maintenance quick and simple.
The JBR Front Sway Bar Kit is compatible with stock and most aftermarket end links.
http://www.jamesbaroneracing.com
*Comparison testing was performed using the Mazdaspeed front sway bar. Increases in stiffness are greater for the Mazda 3.
Features:
-28.6mm diameter bar, 2.6mm larger than stock
-6lbs lighter than stock
-35% - 55% increase in roll stiffness, user adjustable
-Stiffer polyurethane bushings and bushing brackets
-CNC bent for perfect fitment
-Easy to maintain with built-in grease fittings
The JBR Sway Bar Kit Includes:
-JBR adjustable front sway bar
-All necessary installation hardware and installation grease
-Installation instructions are available in our support section
-Shipping is free in the US & our Hassle Free Lifetime Warranty is included
