New Product Release! 2014 MAZDA3 / 6 & CX-5 Rear Sway Bar
JBR
Authorized Vendor
09' & 2011 MazdaSpeed3
The JBR True Torsion Rear Sway Bar significantly reduces the vehicles tendency to push the front end during hard cornering, drastically reduces body roll, and greatly increases traction.
The only rear sway bar for the 2014 Mazda 3/6 and CX-5 constructed out of 32mm 4130 Chromoly tubing with thick solid steel arms. The JBR True Torsion Rear Sway Bar is TIG welded inside and out then the ends are capped. Powder coated for ultimate corrosion resistance. The 2-way adjustability allows you to fine tune the handling for the street and the track.
The JBR Sway Bar Kit Includes:
- New Polyurethane Mounting Bushings & Brackets with Grease Fittings
- Installation Grease
- Lifetime Warranty
- Online Installation Instructions
Everything you need to get the job done right with confidence!!
JBR 2-Way Adjustable Sway Bar Settings:
Stiff setting is 140 155% Stiffer than stock
Stiffest Setting is 250 265% Stiffer than stock
Priced at $205.00 shipped, we've taken the guess work out of where to buy the rear sway bar for your 2014+ Mazda
All the products shown above are available in our online catalog. For more information and to purchase, visit our website.
