New MS3 owner
popwar
I'm Dan , Just got a 2008 MS3 with 103k miles . I had an 03 Silverado RWD extended cab I traded for it . I liked it , but missed turbo and manual . Anyways , the car is pretty clean . It does have some issues I need to fix soon as possible . Needs rear shocks soon . o2 sensor , and I'm pretty sure turbo seals are done for as the white smoking intermittently at idle after idling for a few minutes . Its not terrible but its there . Guessing that's the cause for the o2 , if its covered in oil . Throwing a few o2 codes and a p0300 random misfire which is probably due to secondary o2 malfunction , or so I've read . Drives fine , runs fine other than slight roughness at idle from the codes being thrown . Still pulls good also . Just made this thread to introduce myself , i'll be browsing these forums often . Thanks :)
