Today i mounted a new set of Hella horns € 26,00 $ 33,78.
Hella TwinTone TE 16 110 dB.
Remove the plastic piece around the hoodlock, by removing the plastic clips (2pcs) then slide it towards you.
Now remove the plastic clips from the bigger plastic piece (4pcs) remove the smaller plastic clips (3pcs).
And unscrew the phillips screws (4pcs).
Drill out the rivets (4pcs) to get easy access to the original horn (right side ) and negative ground and bracket (left side).
Take the plastic piece under the air intake away, and slide it towards the engine.
Now you have plenty of room, for the job.
Then wire the left horn + and - , connect the - to the left bracket and bolt on the new horn.
Lead the cable 2 x 1,5 mm2 to the right side (original horn) in the middle(under the hoodlock) is a bracked to tie up the cable.
Cut off the original connector, and wire the right horn.
Now bolt on the new right horn.
Wiring diagram http://www.griotsgarage.com/text/pdf/77573.pdf
Dont know yet what to do with the now missing rivets, maybe plastic clips (because of the oval holes in the metal piece).
I, am very satisfied with the new sound.
LISTEN, OR TRY OUT ANOTHER SET OF HELLA HORNS ! http://www.hella.com/MicroSite/horns/
