I've read in other posts that camber is not adjustable on the CX-5, but I'm looking for a solution to excessive wear on the inside tread of the right front tire. Rotating the tires every 5,000 miles slows the wear down, but eventually the inside of the right front still wears out prematurely. The specs from the last alignment are left -0.51 and right -0.90 degrees. Toe is 0.04 degrees for left and right. I'd like to reduce the negative camber on the right front. Would Eibach front camber bolts work to reduce the negative camber? http://www.ebay.com/itm/Mazda-CX-5-13on-Eibach-Ez-Front-Camber-Bolts-PAIR-5-81280K-/331404036196
