Like the title states, I'm looking for a "How To" on how to change a head gasket. I searched for it but didn't come up with anything.
Thanks everyone.
Thanks everyone.
I've replaced them on motorcycles before but never a car so I was afraid that it would be too much to handle. Here's the question though...I have no compression problems or anything, just oil coming from the gasket (in between valve cover and head). Is a new head gasket necessary or is the oil just from "sweating"? I should add my car has sat in my garage stored over the winter.
if you just have oil in between the valve cover and head its most likely just the valve cover gasket. thats an easy one.
just remove the valve cover, replace the gasket and voila.
if u had a head gasket issue, it would have compression issues, and oil and coolant mixed in the pan.
Yeah it's the valve cover gasket than for sure...on that note, does anybody have a how to for changing the valve cover gasket and how important would that be to change since there is only surface oil on the head (aka sweat).
I'll help you out with the valve cover gasket when I get it in a few weeks![]()
