need hard piping
Moscarsado
03.5 Mazdaspeed
Can someone please tell me where to order hardpiping, i've looked on alot of web sites and i really havent seen any. Please let me know. #582 blazin yellow.
I just bought from them and put my pipes on today with the Turbo XS H34 BOV and it seems to completely eliminate the turkey noise found with my Injen CAI
did you remove the stock bpv? or relocate it?
LzrBlu2003MSP said:
I just bought from them and put my pipes on today with the Turbo XS H34 BOV and it seems to completely eliminate the turkey noise found with my Injen CAI [/B]
WOw ? you wouldnt have any sound clips would you? and btw what are the pipes made out of ?
and 20+hp for hardpipes? possible?
LzrBlu2003MSP said:
I don't have any sound clips of it right now because I am having problems with the setup. My friend thinks I have my BOV on the wrong pipe or its recirculated wrong. But like I said there is no turkey, just the Psshhhhh. Check out my Help thread if you know much about this stuff
http://www.msprotege.com/vbb230/showthread.php?s=&threadid=44753
The other post you started said that you were having problems. A By-Pass Valve should be almost silent. A Blow Off valve makes noise.
I'm thinking that you have it hooked up incorrectly. It should dump back into the intake plumbing after the MAS and before the turbine inlet.
Later...Brian
You having any stalling problems?
I did have stalling problems and I thought I had a vaccum leak (which I did) and I redid the setup and it works fine. I still highly recommend them.
