you dont need custom axles either. you just need to find a fitting axle that has the spline count and length you need. when we did the KL install on the protege, we ended up using a Kia axle that was the correct length and spline count we needed. its just having to sit down, and do the research.
and this swap wouldnt be as bad as alot of people are making it sound. most of the engine and trans mounting location area's are shared between both engines. Thats not saying it will bolt up, but the fact the mounts are in the same spots means not having to fabricate all new mounting spots which can be a MAJOR pain.
