Mazda Connect Firmware update stuck at 19–21% and frozen radio
Hello everyone,
I’m reaching out because I’m having major issues updating the Mazda Connect system on my Mazda 3 (2015, EU model).
My current firmware version is 56.00.513 EU N. I’ve read that in order to reach the latest 74.00.324A EU N version, it’s recommended to first update to 70.00.100A EU N.
So, I downloaded 70.00.100A, placed it on a USB stick together with the failsafe file, and followed the instructions (failsafe first, then reinstall package with codes 3 and 2).
The problem:
The update always gets stuck between 19% and 21%, then the system restarts and shows an "unsuccessful update" message. I’ve already tried:
- Removing and reinserting the ROOM fuse multiple times.
- Restarting with the BACK + NAV + VOLUME combination.
- Using a FAT32-formatted USB stick (32 GB).
- Repeating the whole procedure from scratch.
At the moment, the radio is completely frozen.
After attempting the update, the Check Engine light also appeared (it wasn’t there before), although I was told it’s unrelated to the CMU update.
Some clarifications:
- I have NOT installed any CarPlay/Android Auto hardware module.
- I do not have firmware 59.00.546 (not sure if it’s required as an intermediate step).
- I’m unsure if I should try updating directly to 74.00.324A or if that’s risky.
- I don’t know if downgrading to an older version (e.g., 31.00.xxx) is possible.
I’d really appreciate if anyone who has experienced a similar issue could guide me through the correct procedure, or possibly share the correct firmware files for the update.
Any suggestions are very welcome, as I’m currently stuck.
Thanks a lot in advance for your help!
if it's stuck and now unresponsive, the CMU is bricked... there's ways to take it apart to fix it, but it's highly technical
the best thing to do is to get a used CMU from a car with the same specs, and put it in, the upgrade with a RELIABLE USB drive, no more than 16GB in FAT32 only
