My new/used/recycled pedals
Monstermile
Yes I have one
Had these left over after I traded my Focus in. They are OBX pedals that are modified by KURTZ KUSTOMZ MOTORSPORTS to fit the Focus. The Focus gas pedal is curved so no aftermarket pedals fit. KKM modify the gas pedal by curving it to fit nicely on the Focus gas pedal. I just unmodified it by bending it back straight. They're a little worn but they'll do for now.
Thanks. Clips on all four corners of the clutch and brake and bottom of gas and also two self-tapping screws on the gas. That is the way they had to be installed on the Focus. Don't really need the top clips on the gas with the two screws. Only problem I see is the two top clips on the clutch hit the carpet with the clutch engaged. Might start wearing holes in the carpet.
either wear away at the carpet or whats worse which happened to my friend is it can get caught on the carpet. but his was the gas pedal that got caught and luckily he had a manual trans so he thru it in neutral and pulled over to take it off.
