OK, I searched all over for this and couldn't get a definite answer. Without discussing whether it's actually an upgrade or not, what kind of rewiring has to be done to make this change. I've got no problem cutting and splicing, and I've figured out which wire is which, but my concern is going from the four bulbs always on (w/high beams) to the 2 dual filament bulbs. I assume if I just cut and splice, the H4s will burn both filaments when the high beams are on. Is there a wiring fix, or do I need a sedan headlight stalk? Or is that really a problem? Any help is appreciated, especially if it's been done before.
Thanks
EDIT: Look at my last post for a wiring diagram. Also, keywords: headlight headlights protege5 pro5 , since I couldn't find this damn thread in a search my damn self!
EDIT (10/7/04): Added diagram for installing P5 lights on a MSP.
Thanks
