I'm in here searching for any comments re a cold stall problem I'm having with my "07 MS3. Cold as in below zero F, -30 has been the coldest so far. It starts right up just fine, maybe 1-1.5 second cranking time (a spoken one thousand one, a real second, not a fingersnap) hits its' fast idle and is smooth, then about 3 seconds into idling stalls quickly, not a chug chug sputter to stall, but off as if ignition disappeared. Seemed the first couple times I noticed it it coincided with when I let out the clutch with the trans in neutral to go back into the house and I assumed it was related to trans fluid being so thick at such low temps. I swapped out for syn trans fluid, no change, just did that Thurs after work, stall was the same Fri and Sat am. I've checked for service bulletins at work, none related that I could find. Vehicle has 54K, Mazdaspeed cold air intake only engine mod. Any suggestions would be appreciated, I have access to a full range of tools and diagnostic equipment, just hasn't been enough of a problem yet for me to spend the time poking around. Symptom seems to be gone when temps are roughly 15 or above and when it doesn't stall it shows no sign of wanting to stall, either all or nothing seems so far.
Thanks for your support.
