It remembers the maps, if you have a laptop you should save your maps to your hard drive.bamflee84 said:Hello, wanted to know if when the battery is taken out or a engine rebuild happens does the MPI tuner reset the maps or does it remember them? I am currently having my engine upgrades and wanted to know if this happens, then i know if i need to get the car retuned.
(iagree)mike2225 said:It remembers the maps, if you have a laptop you should save your maps to your hard drive.
What kind of fuel problems do you think that you will have?Are you having Nick rebuild your motor?if so just take your laptop to Nick and im sure he could download the software on to it, and once its on you computer you really dont need the CD anymore.If he cant then i could burn you a copy of my CD as long as you pay for the shipping.bamflee84 said:Mike2227 yeah that was my concern, i bought the car already installed with the mpi tuner on it, and the software cd was not with the car. My concern was that on my car there is an extra two injectors that are welded into my intercooler i didn't want to have fuel problems after my motor rebuild. But if it remembers the maps then i should be fine with leaving the injectors active after the rebuild. I spoke with Nick who told me if i wanted to just disengage the two injectors and I would be basically running off the stock map. Do you know where I can pick up the software disc, or know if anyone will burn me a copy. I plan to have my car road tuned by Nick once that engine is broken into, and see if he can save me a copy of the map on disc. Any other suggestions on what i should do.
How come your rebuilding the motor?Also do you have an A/f gauge? If you do i would keep the injectors plugged in and see how it runs and if its too rich do as nick said and unplug them and run off the stock map.bamflee84 said:mike2227 Well my only worry is that i will run to rich with my fuel. Nothing to major just don't want to flood out my engine. No Nick isn't the one rebuilding my motor a shop up north jersey is. I didn't know about Nick's shop until after i had these other shops do my rebuild. I'll bring my laptop with me and ask him before hand about that software and see what hes says, if hes not willing to or for what ever other reasons, I'll def take you up on the offer for the software. I appreciate you offering and paying for shipping would be no problem. I just don't want be stuck without having the capability of re programing my map if something where to reset it.
I did get my car tuned by nick and it ran like crap.I had a lot of issues the way nick had it setup using the turbo module.I went down to speedcircuit and dana rewired the mpi and runs so good now.I tune the car myself,I have my friend drive while im on the laptop.bamflee84 said:Mike did ever go to Nick to get your car tuned? Where up by you do you get your car tuned?
My BadWitchdoktor said:*bites his toungue*
All i needed was a better brand of fuel injection cleaner:bs:Witchdoktor said:and when your car ran like s*** did you get the list of parts that you should replace because it's not the mpi's fault
mike2225 said:All i needed was a better brand of fuel injection cleaner:bs:
Kooldino said:LMAO.
mike2225 said:Bamflee84 really though, take it from me and many others talk to KOOLDINO he will get your car to run like it should
